Larry Weibert
- 119
- 43
- Youngstown New York
I finally got around to mounting the MRAP Rims on the Deuce. Based on some reading here i reached out to Copper State Bolt and nut as they seem to have a good price.
It takes 10 - 1 inch bolts for each to mount the adapter plates to the rim. The rim measured 1 1/4 thick plus the 3/8 Adapter and a 1/8 washer so 1 3/4 inch plus the nut is 1 inch thick so 2 3/4 bolts would work as listed in other posts. The question is should I use course or fine threads. Course is 8 pitch and fine is 14. If i use fine thread i need to go with 3 inch so 1/4 inch of thread will be exposed no big deal. I planed on using a flat washer as i noticed that the outer rim piece has a slightly larger dia hole then the inner rim piece, so i thought the flat washer would help. Any feed back? Thanks in advance.
