tkgvz
- 0
- 1
- Midland, VA
Just pulled 4 hawkers out and two were seriously bad and other two were borderline. Anyone out there know of a good replacement? Same size would be great and terminal location. Thanks.
Roger that. Yeah I meant stud post location. Just so I wouldn’t have to make any new cables. Thanks for speedy reply.Group 31s group 24s. Group 65s. Cheap anywhere. I recommend stud post so you can cut down on having terminals
I mean stud post so you can have secure posts held down with a nut. Over the battery terminals you have nowRoger that. Yeah I meant stud post location. Just so I wouldn’t have to make any new cables. Thanks for speedy reply.
Will the brackets work the same with those groups of batteries? Height/width/lengthI mean stud post so you can have secure posts held down with a nut. Over the battery terminals you have now
You can modify the bracket. Lots of us just use bungee cords over those junky bracketsWill the brackets work the same with those groups of batteries? Height/width/length
Ok. Cool. Maybe just have to make up a couple cables then. I imagine the location of terminals or studs on new batteries will require this.You can modify the bracket. Lots of us just use bungee cords over those junky brackets
