- 226
- 13
- 18
- New Orleans
The '73 M35A2C has been distressingly idle the last few years...many more hours at rest than driving. I typically fire it up and run it for an hour or two on a weekly to bi-weekly basis. Occasional it gets to 3-4 weeks. Replaced the batteries w/in the last two years and have been running it farily regularly. Today it did not fire and run immediately as it typically does, but caught and ran as the batteries were running down. After the oil pressure came up I ran it for a half hour or so at ~1k, then ran it for another half hour at ~ 1.6k. When I pushed in the rev control, it gradually dropped down to ~700, then dropped to ~500 and stalled. It would not fire up after that.
It has been under cover the last year and a half. Last fuel fill was well over a year ago, and it's down to about a quarter tank. Tomorrow I'll add 10 fresh gallons with a bit of 2-cycle oil and a can of Seafoam and try 'er again. I am more than open to alternate suggestions for another approach, or for a different recipe. I likely will pick up a can of ether for luck, but I am not clear as to what prep I should do before trying to use it, or actually, how to use it.
I'll see if I have fuel filters, with the thought of changing those. Can't hurt. Time to delve into the TM again.
Bummed out.
bs
Bummed out.
bs
