Headlight trouble began with the wife reporting the headlights being inoperable even after toggling the service light switch. After a few minutes she noticed they came on. I checked myself and they worked just fine.
Last night however I pulled the switch and got nothing Quickly checked my fuses and found them to be fine. While digging around under the hood the lights suddenly came on....just as the wife had earlier described. Went for fuel and this time, I initially noted my brake lights working and I shifted the truck into drive. As soon as I pulled the headlight switch I lost all lights. Today I began by pulling the dash and checking voltage. The service light toggle switch tested operational, with voltage passing to the headlight switch correctly. The measured voltage instantly disappears at both the headlight switch and the service toggle when the switch is pulled to either position. I should note that I tested both the original headlight switch and a new autoparts special with the same results. Voltage at the diamond shaped firewall junction block was fine with the switch on, which would mean battery power upto the fuse block is good.
I am confused as to why the 30amp headlight fuse is not popping? I'm not sure what to test in order to get to the bottom of my no lights issue. Any advice? Thanks in advance.
