m170spare tire mount and bar
CPDOG
24
SEABECK WASHINGTON
hello again to all:
I am looking for the spare tire mount / bar for M170 Jeep. hard to locate, I know.
or does anyone have access to a dwg (whether original or not) or does anyone now of someone who had these bars fabricated up and still have the bend radius chart available?
thank all of you for reading!
jasonjc
290
Gravette Ar.
hello again to all:
Did you ever find any thing on this??
CPDOG
24
SEABECK WASHINGTON
Hello Jason
I did find a guy who made these but when I got it was off by 3” on each end and the height was off by 1 1/2 “. So cut it in 3 areas to fix the length and replaced the 2 center pieces with taller ones, after that it fits very nicely, I have attached pics for you too. This M170 is a challenge for sure😀😀
jasonjc
290
Gravette Ar.
Hello Jason
I don't see your pic's. Do you have any measurements and do you know what size the pipe is? Are all the thing made with pipe on it the same size? I.E. the bows, the handle on the dash, the tire rack .
Thanks
CPDOG
24
SEABECK WASHINGTON
Thanks
Jason
I will look at those tonight and get back with you repost pics too, I didn’t know you were looking for any measurements initially, talk again soon
CPDOG
24
SEABECK WASHINGTON
Jason
hello again Jason,
ok all tubes for seats, front support bar on dash for litter, tire mount bars and the bow rails are all 1" tubing, this time i am loading pics from home computer vice the phone so i believe we will have a more success this time. also i found another site with the tire mount dimension and they are there for other to use, it might assist you , it definitely did for me when i had to re-do the mount that i got,........ http://www.willysmjeeps.com/v2/modu...ame=gallery&file=index&include=view_photo.php .......... once you log in, reenter this site address and then it will take you straight to the tire mount dimensions he posted, also there are other m170 data there too. lastly, i threw in a few more pics of the restoration to show how crazy it got, we even had a new gas tank made as the new old stock tanks are just fucking ridiculously priced, and then we raptor lined the whole inside,,,5 gallons worth:):) the windshield we had to buy a new one and then re-weld all m170 parts back on to it, the tailgate was the same situation they don't make them so we took the original and painstakingly transferred all dimensions to it and did fit ups with the litters and got it to work fine, the seat cushions we had made and got the thickness dimensions from the floor ribs width and we also had to have 2 seat springs made up too, these things are cushy1607565341840.png :):):) anyways good luck to you.
jasonjc
290
Gravette Ar.
hello again Jason,
ok all tubes for seats, front support bar on dash for litter, tire mount bars and the bow rails are all 1" tubing, this time i am loading pics from home computer vice the phone so i believe we will have a more success this time. also i found another site with the tire mount dimension and they are there for other to use, it might assist you , it definitely did for me when i had to re-do the mount that i got,........ http://www.willysmjeeps.com/v2/modu...ame=gallery&file=index&include=view_photo.php .......... once you log in, reenter this site address and then it will take you straight to the tire mount dimensions he posted, also there are other m170 data there too. lastly, i threw in a few more pics of the restoration to show how crazy it got, we even had a new gas tank made as the new old stock tanks are just fucking ridiculously priced, and then we raptor lined the whole inside,,,5 gallons worth:):) the windshield we had to buy a new one and then re-weld all m170 parts back on to it, the tailgate was the same situation they don't make them so we took the original and painstakingly transferred all dimensions to it and did fit ups with the litters and got it to work fine, the seat cushions we had made and got the thickness dimensions from the floor ribs width and we also had to have 2 seat springs made up too, these things are cushyView attachment 820426 :):):) anyways good luck to you.
Nice work!!! Thank you so much for the info , it seems to be hard to come by. I see on a lot of site's M-170 question go unanswered.
CPDOG
24
SEABECK WASHINGTON
Hello jason
You are correct on the reply issues. Be sure to share your m170 , these are hard individuals to play with, so all tricks / ideas are most welcome
parrottt
10
Polkville, NC
In the last month of so I have somewhat restored my M170, which my research shows was a Marine Corp Radio Jeep. All the parts back of the dash are almost impossible to find. As for the seats I used the passenger seat for the M38A1 on the drivers and the passenger side. Found the cushions and covers on ebay. The cover is made out of the same material that is used on canvas commercial awnings. I was not trying to make the restoration original but just to look good (15 foot or moving rule). Mine is an everyday, weather permitting, driver here on my farm in NC. I did find a way to convert the oil bath oil filter so I could use a Wix paper filter.
Good luck with the M170, I have had good and bad luck, but worked through it.......
CPDOG
24
SEABECK WASHINGTON
hello parrattt
was that kinda of a kit there? please share some part numbers for the material if you have them available....thanks!!!
parrottt
10
Polkville, NC
hello parrattt
Wasn't a kit. I found a post on one of the military vehicle sites some time back and lost track of where Sergeant Major of the Gee posted it on the site.
I replaced the guts of the oil bath air filter. I ran across the post on the internet about replacing the guts with a NAPA Gold 2036 air filter and putting two “Fluidmaster Better Than Wax 5.5 inch Wax-Free” Commode floor gaskets (from Lowes) on the top and bottom of the canister. It fit and worked perfectly. I used a section of automobile ac/heat tubing to connect the carburetor to the filter.
A story about restoration is on the Kaiser Willys site under Barn Yard Restoration 1 and 2
Hope this helps
Parrottt
CPDOG
24
SEABECK WASHINGTON
View attachment 823334 View attachment 823335 View attachment 823336
Hope this helps
Parrottt
hello!
thank you for responding, very cool mod, i am going to look into it as well.
jasonjc
290
Gravette Ar.
JASON HERE IS THE NAME OF THE FACEBOOK PAGE TOO: Willys M170 Jeeps 1953-1963 TYPE IT IN AND SEARCH IT:):)
I'm signing up for it right now thank you
Just got approved for the Facebook group. Thanks for the info. Like all your posts on there.
CPDOG
24
SEABECK WASHINGTON
hello Jason, thank you! i am doing more this week on individual things we did during the rebuild, see you on there. i just found new in the original wooden crate: heater kit and a new in the original box snorkel kit. see you later
