Tailwheel
- 58
- 18
- Charlotte, NC
So I went and drove my truck and noticed a weird feel/noise on shutdown. Fired it back up and the crank pulley started wobbling. I’ve removed the damper and am doing front/rear seals, timing cover seal, HF water pump, HO oil pump, etc.. I purchased a new GM damper.
I used the proper puller and had one hell of a time getting the damper off the crank. Once off, the crank was overall clean, straight, but it had some gouges. The keyway is in excellent shape.
Looks like someone has pried on the crank with a sharp edge and put gouges and burrs on the snout. I was able to file down the burrs and the majority of the surface is fine but how concerned should I be? I don’t have pictures on hand.
Should I be concerned about crack propagation? If it’s time to replace this engine I’m selling the truck. I have too much money and sweat equity into it at this point and I’m not getting any form of return.
