WildernessJeep
- 91
- 28
- Huntsville, Texas
Yes. There is a bypass modification that was done. It is a valve under the steering wheel that says spring brake override. Not the one on the dash. It overrides the spring brakes for the PTOI got my M936 slightly stuck this weekend. There was a big tree to the rear, but I couldn't winch to it because ALL the wheels lock with the crane in gear. Has anyone figured out a way to bypass the wheel brakes with the crane in gear? View attachment 822612
Correct, but that only unlocks the front wheels, not the rear.Yes. There is a bypass modification that was done. It is a valve under the steering wheel that says spring brake override. Not the one on the dash. It overrides the spring brakes for the PTO
No. The front wheels are service brakes they never lock. They never lock. The one under the steering wheel is for self recovery to release the brakes so it doesn't bulldoze.Correct, but that only unlocks the front wheels, not the rear.
Specifically, there is a kit (maybe aftermarket) that locks the front wheels, too. Yes, the spring brake emergency release button (under the steering wheel) releases just the front brakes. The parking brake releases the rear axles.No. The front wheels are service brakes they never lock. They never lock. The one under the steering wheel is for self recovery to release the brakes so it doesn't bulldoze.
If it's not working then it is prob hooked up wrong or you don't have it.
Only option you have is to cage the spring cans in the rear
From the manual. "If using the wrecker’s rear winch for self-recovery,
You lock the service brakes by attaching an air hose from the emergency gladhand on the front to the service gladhand on the front this applies the service brakes.Specifically, there is a kit (maybe aftermarket) that locks the front wheels, too. Yes, the spring brake emergency release button (under the steering wheel) releases just the front brakes. The parking brake releases the rear axles.
They got it out with six trucks/winches, all on double snatch blocks.What's the "buried to the axle vehicle count" at this point? No half ton pickups are going to pull that out. Think D6 dozer.
Another question: On the front winch, the clutch lever should be in the "OUT" position when winching, correct? The manual only says "move the lever as far back as it will go". My lever moves left/right, not front/back. It is indicated clutch "in" or "out". I assume "out" means the winch is engaged, correct? Is there ever a time you wouldn't need it engaged? It won't freespool at all in either direction.From the manual. "If using the wrecker’s rear winch for self-recovery,
release parking brake and set spring brake
override."
How to "set spring brake override"? It's a momentary button, correct? How would you keep the button in while operating the winch (from the right rear of the truck)?From the manual. "If using the wrecker’s rear winch for self-recovery,
override."
Right. That's my question. The "handle with a ball" is the clutch lever. The manual only says "move lever as far back as it will go". The lever is labelled "clutch" with an "in" and "out". It doesn't move front/back, it moves (to the driver) left and right, towards and away from the winch operator respectively. My winch doesn't seem to "free spool" in either position, but it is a pretty heavy winch/cable, so maybe I'm just a weakling. Regardless, giving instructions in front/back or in/out are not understood.On the front of the winch, on the driverside between the winch and the hood, there should be a handle with a ball at the that should push/pull if standing, facing the side of the winch. One direction free spools it, the other engages/locks the winch in for operation.
I don't remember, and i am in chili, sa till the middle of the month, or i would go fire mine up and mess with it. i think, away (push towards the passenger side is engaged). So, in might might refer to engaged/line in, and out refers to disengaged. I am assuming you can line in and line out, but not free spool. Correct?Right. That's my question. The "handle with a ball" is the clutch lever. The manual only says "move lever as far back as it will go". The lever is labelled "clutch" with an "in" and "out". It doesn't move front/back, it moves (to the driver) left and right, towards and away from the winch operator respectively. My winch doesn't seem to "free spool" in either position, but it is a pretty heavy winch/cable, so maybe I'm just a weakling. Regardless, giving instructions in front/back or in/out are not understood.
So my questions are 1) for winching, should the clutch lever be to the driver's right or left (in or out); and 2) how to confirm the clutch is or is not engaging correctly?
