I thought my dump had hawkers but I found I had Exide. This is the only one of 15 5 tons that started under its own power when I bought it and with some convincing (charging) has lasted a couple years without major attention. I sure was glad to find Exide, it seems my small charger works with them, where recharge of Hawker....no.
I have two out and two others ready to come out. Initially the first 2 read around 10.5 and 11.2volts open circuit. There was not much corrosion but had some, with a couple loose bolts. Now, using my 2/10 amp charger, the hold at 12.35v and 12.45v. I read that full charge will hold at 12.9v. This will take days with my small charger, but my success on Exide is very good. Oh yea....manufactured 2009.
Photo is of 2 amp setting and the 10 amp. On the 10 amp manual setting it's charging around 15 volts, so I'll stay with the 2 amp at 13.5.
If you are noticing the polarity of my meter, the leads are switched.
