Fuel issue , bad injection pump?
MDF1017
Texas
Thanks for everyone’s advice, I’m gonna look at IP rebuild. Should I change injectors while I’m at it?
frank8003
4,987
Ft. Lauderdale, Florida
Do the jobs one at a time to get improvement. Somewhere here in repair process get the fuel gauge functioning proper or use a stick you calibrate.
If the correct functioning lift pump is in there then do the filters and injectors.
It ran out of fuel so whatever was in the last of that fuel went to the injectors, thru the entire fuel system. It is logical that crude and crap went to those injector orifices.
You can give the seafoam a try, cheapest and simple but you can just dump in a quart of naphtha
(the pale oil in Seafoam is a non wax naphtha oil). from local store.
