The tough thing about this is that you think you have done everything, and we don't know what you have really done, so it's hard for us to know where to point you. You probably missed something basic, and yet you are sure you covered all the bases. We all do this from time to time, so don't think I'm putting you down. It's just something we fallible humans do.
The hard part is forcing yourself to go back over the same ground, because "I
know I checked that! DON'T TELL ME TO CHECK IT AGAIN! I KEEEEL YOU!".
But I can't tell you how many times I've said that and.... whoops. I missed it.
The other thing is once we get frustrated, we start jumping around, and that makes it even more likely that we miss something.
All I can suggest at this point is that you assume nothing, and start from the beginning. Don't jump in and try this and that. Start with the troubleshooting guide in the TM, and go
- ONE
- STEP
- AT
- A
- TIME
Don't skip ANYTHING, don't assume anything, no matter how sure you are that you already checked it. AND WRITE EVERYTHING DOWN!!!!!!!
If you don't, you WILL forget something critical. Get a notebook or something and have it right there with you. Do NOT rely on your memory. Draw diagrams, make lots of notes.
Also, remember that the Gen lights on the dash are a critical part of the charging circuit. Could be as simple as a bad bulb, bad socket, or a bad trace on the circuit board.
Follow my advice and I'm sure you will find the problem, and then kick yourself because it's going to turn out to be something simple.
Holler with
any and
all questions!
