MEP-806A antifreeze?
SandBar
Full Time Patriot
756
231
GA/FL
Moving on to a bigger generator at long last. I want to order all the filters and fluids to have on hand when I pick this unit up next week. I have the TM's and maybe I am overtired, but I cannot for the life of me find the specs for the correct antifreeze to use. Anything off the shelf rated for the John Deere engine it has should work?
SandBar
Full Time Patriot
756
231
GA/FL
I think it is A-A-52624A, but how do I translate this into an off the shelf antifreeze? I see talks about SCA's and using the wrong antifreeze can destroy the liners... I never knew coolant could be so complex.
MrShawn305
97
El Paso, TX
Just curious, what are you upgrading from? What do you run that you require such a large machine?
SandBar
Full Time Patriot
756
231
GA/FL
5500 sq ft house with shop and climate controlled barn and rv plug. Had a 17kw that couldn't handle all the load so had barn on a separate generator.
MrShawn305
97
El Paso, TX
Dang! As far as coolant goes, I use the red heavy duty stuff. Shell Rotella ELC, my buddy buys it premixed in 55 gallon drums. He works on a lot of busses so he keeps that and Rotella oil on hand.
