springer1981
- 1,151
- 93
- Maine
Why would it slide with bumps? The rearend doesn't move and the eng/trans/tc doesn't move. Bumps don't effect anything.You may also need to reset the pinion angle based on those issues. You may also disengage the rear driveshaft from the transfer case if it slides too far with bumps.
I was just messing around with photoshop but that's great that someone did it. Just when you think you've got an original idea LOL.
I think with a different engine you could take 12" out right down the center and it would still be 6'2" wide. It would be a lot of work to move the frame rails closer and take 6" out of each CV shaft. I definitely think it could be done and would look more proportionally correct. I'd be afraid a shortened Humvee at stock width, it would look almost square from above LOL.I like the idea of the conversion to narrower, that would be an original concept.
Build one, (And), Likely the 'Government' will order 100,000. (Who knows..).
When they moved the engine back closer to the CG, they put it nearly between driver and passenger. That would seem to make narrowing really a challenge.I like the idea of the conversion to narrower, that would be an original concept.
Not an issue, the differentials are frame mounted and move very little.You will have significant issues with rear driveshaft length being too short and creating too acute of an angle. You may also need to reset the pinion angle based on those issues. You may also disengage the rear driveshaft from the transfer case if it slides too far with bumps.
Better idea is to eliminate the rear doors and extend the rear quarterpanels forward. You can then move the "B"-pillar a bit more to the rear, move the bar behind the seat back with the B-pillar, and in so doing create a reclining seat with more leg room. Then stretch fabric doors or fabricate stretched fiberglass doors to fit the wider driver's and passenger's door portals.
The picture was off of govplanet that I chopped up. The line drawing are from a goggle image search and then edited.Springer, did you start with a drawing or draft one yourself? I'd like to see a lowered 4door 4x2.
