The 12V cable is the one that has 4 battery terminal connectors on itSo, I'm going to go with two batteries. Four just doesn't seem to make any sense; financially or otherwise.
How do I identify the 24V vs 12V cable? Maybe it will be obvious when I look at it, but the only cables I recall being obvious are the NATO plug wires.
And it's been a good one! Some good info. I had no idea about the Alt/Generator charging issue. That aspect of how to set up your vehicle never occurred to me and it's kind of a big deal.Based on the thread title, I must thank you. Finally done with all battery threads after this one. Finally!
It's a 1997. I thought all the cables came in from the upper left. I'll have to look closer.What year truck?
If an AO (facing truck) there are two cables coming in inboard/forward (top/left). These are your 24v (on the AO's the two are paired together, on the A1R it is a single cable (I've never owned an A1).
Then one single inboard/middle (center/top). This is 12v
And one that reaches all the way to the outboard/aft (closest/right). This is ground.
If you make a single jumper between the + and - , then you can save the takeoff cables incase you or next owner wishes to revert to quad bats.
A0 version truck.It's a 1997. I thought all the cables came in from the upper left. I'll have to look closer.
I did the exact same thing. Yes, all the cables come from the left on mine as well. It was actually fairly easy to figure out once I was looking at it.On my A0 all the cables come in from the upper left. On mine the 4 connector 12v cable was made up of bolt together 2 terminal units. I reused one of these for my 12-24 jumper between the 2 batts...
The fact that the batteries are AGM is not what was being debated. AGM are always better batteries than conventional flooded lead-acid. It was the size that was being problematic.ok..... so now question in a different direction (literally) since previous conversation has a logical lean to the "starter" batteries
scenario one- Not my case but it may be for others building Poo Man's campers.
> Oem 100am 28/14 Niehoff<
. what about 24v "House" batteries charged via a battery isolator connected to alt and the two different banks of starer and house. Isolator; once the "starter" batts are charged then sends juice to House batts.
? AGM still a no- no for house bank here?
scenario two- my case Hummerized alt
>200amp 28/14 Niehoff<
. Again- 24v "House" batteries charged via a battery isolator- once the "starter" batts are charged and Islolator is sending juice to House batts.
? AGM still a no- no here?
sure would be nice to have AGM for house. Yeah true; sure would be nice for lithium...... but lets leave this out of conversation for now cause does not meet the "poo mans" criteria.
thanks...... math makes since but figures dont?. Am I wrong to see it i as the 100amp OEM 14/28v is not 100amp.... it is instead in more simplistic terms only up to 50amp for each 24v and 12v? If so then the Hummer one would then be in simplistic terms be 150amp 24v & 50amp 12v?The fact that the batteries are AGM is not what was being debated. AGM are always better batteries than conventional flooded lead-acid. It was the size that was being problematic.
Each 6TL is 100 Amp-Hours (AH), and so with four you have a total of 400 AH. Even at 100% efficient, (which it is NOT), the 100A alternator would take 4 hours of constant running at peak RPM to charge those batteries (400Amp*Hr / 100Amp = 4Hr). .....
I think the subtlety not coming across is that none of this stuff ever works at 100% capacity. So I was using the simple numbers, and came out with 4 hours, but the reality is that you may only be getting 1/2 that AT PEAK, because the alternator is old and not delivering it's 100%, the batteries are old and not taking the charge 100%, the length of cable has a lot of resistance cutting it down further, etc. When idling, you may only be getting 10-25%.thanks...... math makes since but figures dont?. Am I wrong to see it i as the 100amp OEM 14/28v is not 100amp.... it is instead in more simplistic terms only up to 50amp for each 24v and 12v? If so then the Hummer one would then be in simplistic terms be 150amp 24v & 50amp 12v?
Also in scenario questions is asked 12v is irrelevant.... that won't be hooked to the battery isolator.
I don't think so...Am I wrong to see it i as the 100amp OEM 14/28v is not 100amp.... it is instead in more simplistic terms only up to 50amp for each 24v and 12v?
I think that may be the max from either leg at once, not the combined.I don't think so...
My 260a on my truck makes 260a on the 28v side and 140a on the 14v side. Now whether it alternates that thru the magic smoke contained within or if it does it at all the same time, I've no idea (I suspect the former).
If memory serves, the 100a OEM 28/14 puts out 100a/40a respectively...grossly underpowered.
Wind chill temp doesn't matter, just the actual temp. Wind chill temp means that the wind is blowing heat away as fast as if it were that temperature, but you still will not actually drop below the real outside temp under any circumstances.Wind chills down to -5 below zero so kind of nippy outside right now.
If one is bad, all kinds of goofy stuff can happen.I was watching the 4 New Batteries I just put in. Found that one 12 volt was dropping and not the other? It was not tied into the other 12 v. Charged all 4 at 24 volts they did not charge equal for me. To get them all floated even I had to do one at a time at 12v. The 12 v part is going down slowly over a few days? It did the same thing with the 4 Red Tops that were in it. Pulled them out and found only one was bad out of the group. I still have them. Going to put a amp meter on the cable to see where it is bleeding off to.
