JD4044M
- 999
- 93
- Okanogan, WA. 98840
Nice Charger but big bucks to at $400.00 each on sale.
They have sales and stuff. I think I got mine <$300, like 4-5 years ago. I assume it pays for itself over time, by maintaining the batteries better and prolonging replacement. I don't know how old the batteries in the truck were when I got it (or how many times soldiers had mistreated them and run them dead), but one finally failed last year, and two this year. So I'm satisfied with it.Nice Charger but big bucks to at $400.00 each on sale.
The CCA/charge current only adds in parallel, but the AH capacity adds both in series and in parallel. So adding 4 batteries @120AH/each equals 480AH.The 6TL’s I have are 120AH(says it right on the lable).. AH capacity is only additive in parallel, just like voltage is only additive in series, so the 4 battery bank on the LMTV is 240AH... a pair in series would be 120AH...
No, Amp hours is the wrong term to express the amount of energy storage gained in series... IE: A 12V 100AH battery would support a 12V@10A load for 10 hours. Two 12V 100AH batteries in series to make a 24V battery, would support a 24V@10A load for the SAME 10 HOURS... It is twice the amount of work being performed, but it is still the same application to the amp hour rating... the 24V unit takes the same amount of time to charge as the 12V unit given the same charge current at the two different voltages. The difference from 12V to 24V doubles or halvs the energy in play, but has no bearing on an amp hours rating. Now if you parallel another set of batteries, you have now added to the amp hour capacity while maintaining the same voltage.The CCA/charge current only adds in parallel, but the AH capacity adds both in series and in parallel. So adding 4 batteries @120AH/each equals 480AH.
(The AH capacity is basically "how big of an energy bucket" they are. So adding more "buckets" literally adds more energy volume to drain from. Or think of it like gas tanks. Putting two gas tanks in series, one after the other, doesn't let you drain it any faster, because it's still just going through one hose. But you do get twice as much volume to drain. And putting two gas tanks in parallel, side by side, lets you both drain the extra capacity of two, plus drain from two hoses at once.)
You're right. The AH rating stays the same, but the "two gas tanks" analogy is still meaningful. In series you now have 2x the voltage, you'll be drawing 1/2 the amps for a given work (Watts), and thus run 2x as long with two batteries. So it is a capacity improvement, and still takes 2x as long to recharge too.No, Amp hours is the wrong term to express the amount of energy storage gained in series... IE: A 12V 100AH battery would support a 12V@10A load for 10 hours. Two 12V 100AH batteries in series to make a 24V battery, would support a 24V@10A load for the SAME 10 HOURS... It is twice the amount of work being performed, but it is still the same application to the amp hour rating... the 24V unit takes the same amount of time to charge as the 12V unit given the same charge current at the two different voltages. The difference from 12V to 24V doubles or halvs the energy in play, but has no bearing on an amp hours rating. Now if you parallel another set of batteries, you have now added to the amp hour capacity while maintaining the same voltage.
The correct term for capacity added by adding in the series dimension would be watt hours, which is not as often used... It is twice as much energy(watt hour capacity), when you add two batteries in series, but you are also drawing from it at twice the energy rate(24V vis 12) so it is still the same draw on the amp hour capacity...
12v vampiric drain?I was watching the 4 New Batteries I just put in. Found that one 12 volt was dropping and not the other? It was not tied into the other 12 v. Charged all 4 at 24 volts they did not charge equal for me. To get them all floated even I had to do one at a time at 12v. The 12 v part is going down slowly over a few days? It did the same thing with the 4 Red Tops that were in it. Pulled them out and found only one was bad out of the group. I still have them. Going to put a amp meter on the cable to see where it is bleeding off to. The Cold Temps I was talking about was me freezing my butt off. I did not have gloves. It is blowing 23+MPH and 39 MPH Gusts at 19 degrees. Did not take long unhooking my batteries to get my fingers froze! Will be dropping down to 1 degree real soon here.
Correct, except the 2x as long to charge part. That would only be true if you are charging at the same wattage input for both voltages. IE: A 12V@100Amp alt is 1200W. A 24V@ 100A alt is 2400W. Now if your 24V alt is only 50A/1200W, then yes, the 24V will take twice as long to charge the 100AH battery, because your alt has half the amp output at the higher voltage...You're right. The AH rating stays the same, but the "two gas tanks" analogy is still meaningful. In series you now have 2x the voltage, you'll be drawing 1/2 the amps for a given work (Watts), and thus run 2x as long with two batteries. So it is a capacity improvement, and still takes 2x as long to recharge too.
I was looking into making my own Lithium battery set that would be mounted under the seats in the cab (For several reasons I will not go into here), but when I came across this from a Lithium battery manufacturer I decided Lithium is not "Military Grade" since it will never satisfy a cold start in crazy cold weather. Bummer. I was wanting to have it integrated with a set of solar panels but if they will not charge when chilled what good would they be? NO GOOD LOL.![]()
Lithium Cranking Amps and LiFePO4 CCA Guide - Power Sonic
Power Sonic's guide to lithium cranking amps and LiFePO4 CCA. We explain what cold cranking amps are on a lithium starter battery. Learn morewww.power-sonic.com
How much are u giving for the napa/interstate 6tlsDual 6TLs on all my trucks.
Mostly because I like the OEM tie down system and didn't want to hack up the top in case I reverted back to four (never know when we *all* may be at war or have to bug out to nasty cold places, etc).But I've seen people retrofit all sorts of sizes. There are a size or two that will fit in the OEM holder, but be advised that one company may add different handles or strap slots that suddenly make their battery not fit. So if you can, see one fit before purchasing two (or four).
There are several threads here and on the LMTV FaceBook page (FB blows goats with their censorship, fyi). Look for ideas. Decide if you want to chop your box lid or make a custom tie down, etc. If you are willing to be a bit creative, it opens more options (and some guys have made some slick battery box solutions). Or if you want to stay OEM. Then work from there.
And AGM's (or gels) are awesome especially if you are hammering around off road and don't want to risk banging the plates around. I don't have that kind of money to spend at the moment (I'd love to try big-arse Optimas or something). But I'm poor, so NAPA/Interstate 6TL's for me.
Great info butt some where it seem i read something about not mixing batteries together with amp hr differences. When we would have a 8d agm go down on the road in the house batteries they would replace both agms at the same time even though just 1 battery went down so they were a matched set is why im hesitent to put reg batteries in with agms with loads of amp hrs compared to not so muchIt seems that the 6T-AGM is the stock battery for the M809/939 series... Correct? But I see in the 5 TON parts list that 8D batteries are listed and the 31 series.. From the sizes listed below the 8D batteries are virtually two 6T batteries put together.View attachment 854230
So I am a bit confused on that... I see talk that just two batteries are fine for the 24 Volt system for civilian use. But 4 is stock Military style.
Question: If your running a dual voltage alternator are you running three batteries? Two for the 24 Volt system and a third for the 12 Volt add on items? Or ???
https://www.steelsoldiers.com/threads/dual-12-24-volt-alternator-on-m932a2.115742/
https://www.ceniehoff.com/Documents/Ctrl_Hyperlink/II0030A_uid121020091141311.pdf
Question#2 If you are going to run only two batteries, would running the 8D batteries give a bit more oomph in the CCA department and the overall Amp hours? These were some examples that I was looking over below.
Group 31- AGM Batteries
Example Battery:
https://www.batteriesplus.com/productdetails/battery/sli/bci-group-31/sli31agm
L= ±13
W=±6.5
H= ± 9.5
± 100 Amp hour
±925CCA
Cost ± 275 USD
Weight: 67
The 6T-AGM Batteries
https://replacementbatterystore.com/fiamm-6t-agm-military-ordnance-replacement-battery/
Sizes seem to vary on these...
L= ±10.47 / 11.26
W= ±11.02 / 10.59
H= ±9.05 / 9.17
± 120 Amp hour
± 1225 CCA
Cost ± 640 USD
Weight = 86
The 8D-AGM Batteries
https://www.renogy.com/deep-cycle-a...4GjOHtSwnCT85zxodfZn5uDk3O0PYAXRoCmzYQAvD_BwE
L= ±20.75
W= ±11
H= ±10
± 200 Amp hour
± 1425 CCA
Cost ±400 USD and up
Weight = 127lbs
4 batteries were chosen to meet a particular milspec requirement like being able to set for a month on the Siberian step in wintertime and still be able to crank the engine long enough to start it with no supplemental heat. Un fortunately the person designing the electrical system wasn’t in on this plan and didn’t put an alternator in large enough to comfortably handle this situation. This is the kind of error that recalls and class action law suits are made of out in the real worldIt seems that the 6T-AGM is the stock battery for the M809/939 series... Correct? But I see in the 5 TON parts list that 8D batteries are listed and the 31 series.. From the sizes listed below the 8D batteries are virtually two 6T batteries put together.View attachment 854230
