Hello all,
Now I have searched high and low and found a lot of good information on suspension, BUT it's almost always exclusively in regards to FRONT suspension and spring sag or leveling options. My issue is that my rear (specifically passenger side) seems to sag a little bit. Nothing major and I assume it has to do with the airlift bumper/ rhino tire carrier I have. Now I was planning on eventually installing a Rubber Duck suspension lift with all new ball joints and the works. However, I would like to start fresh with all new coil springs to get consistent life out of the setup. I also will be converting to four door and don't want any additional rear sag when more weight is added. So, all I can seem to find is standard "variable rate" rear springs. Is there any option in the rear for a heavier duty spring (like plow springs for the front)? If so, any that possibly give a little lift? If I could get an inch or two using front plow/winch springs and some kind of rear upgraded springs, then I may not even get the lift kit. P.S. I have a '92 m998 with GEP 6.5 and is standard 2 door now. Oh, and a level stance in front is no concern, I actually prefer the factory aggressive stance with a slightly higher rear. Any info is greatly appreciated and I apologize for the long winded post. Thanks in advance,
T
T
