Jackson7839
- 0
- 1
- Nebraska
If yours has a good input shaft i might have one you can rebuild.In need of a standyne injection pump mine is full of rust or if anyone has one that needs a seal kit I would be interested View attachment 826810
I can order new umbrella seals but the input shaft is good how muchIf yours has a good input shaft i might have one you can rebuild.
Sent from my SM-G973U using Tapatalk
Sent a pmI can order new umbrella seals but the input shaft is good how much
On all the 005 and 006 ive worked on, the first thing that comes off is the IP and gets sent straight to the rebuild shop. All have been rebuilt. Now the issue with these 005 is the crankcase seals leaking oil. Also, change the oil drain valve and hose. Always leaking. Good luck.Sent a pm
You are right about that. The shop i used wanted to set the speed at 1800 rpm and i told them to leave the throttle lever adjustable so that i could adjust the rpm. So its always good to clarify that with the shop beforehand since they are not used to the mil spec settings.Should you send it to the rebuild shop, include the repair and testing instructions included in the -34 TM. The military adjustments are a tad different.
