CallMeColt
- 1,675
- Wilson County, Texas
Everyone,
I am currently trying to get a MEP-016B generator running. I confirmed I am not getting fuel on the high pressure side of the injection pump due to it being jammed. I want to remove it but it was left in the "off" position so that is where it's stuck.
In the workshop TM, 5-6115-615-34, section 6-3, step 7 requires the pump linkage to be moved to the center. This can't be done.
Because of this, it doesn't line up properly with the hole in the engine block. Both the pin (this is what I am calling it in the attached picture) that goes in-between the governor fork & the cylinder (this is what I am calling it in the attached picture) that guides it in the injection pump itself hit the block. I can lift it enough to get the governor fork out of the way to avoid it getting damaged.
Has anyone ran into this issue? If so, how did you overcome it?
I sprayed some PB Blaster in best I could to attempt to loosen it up. Going to let it sit. My next thought is heat. Besides that, I have no idea. Getting a tool in there is not an option.
Other than this, I think the unit will work well, just sat around for a long time.
Thank you in advance!
