Elk1111
- 487
- 63
- Las Cruces NM
I have a friend stuck in Pecos Texas with a hard brake pedal and the rear brakes smoking. Any ideas how to do a roadside repair to get him rolling again.
I had someone put tacks or small nails to seal off one of mine before. Head was perfect size to seal the line. Wondered why brakes wouldn't work.Take the hotttest drum and disconnect the hydraulic line and plug it.
And, IIRC, if the Master Cylinder rod doesn't have enough free play travel, then it can't vent the pressure when the brakes are released, through that little hole, back into the reservoir.Bleed hole in master cylinder (small hole to the rear, at the bottom) clogged or sticky airpack! My 5 cents.
This is exactly what happened with my m818, I had replaced the MC and the rod was just a tad too long... kept having to stop and open a bleed screw. Thought I got trash in the MC or air pack. Adjusted rod and was smooth sailing.And, IIRC, if the Master Cylinder rod doesn't have enough free play travel, then it can't vent the pressure when the brakes are released, through that little hole, back into the reservoir.
