So I replaced gen 1 alternator because it was only charging to 10volts while rear was charging to 14 I had gen 1 rebuilt and right after putting it in it was charging to 14 like it should and I was getting 28v across both battery’s now a day later front battery is only charging to 12.5 and back is charging to 15 and I’m getting 27v across both battery’s what could be the cause for this? All battery cables and grounds are clean and tight also
update after driving it more the front battery is now down to 10volts like the gen 1 went bad again also my gen2 light comes on and my gen 1 light doesn’t and but I’ve made sure bulb and socket work in gen 1 but light still doesn’t illuminate
