Need tcm for am general M916
fuzzytoaster
3,707
Fort Worth, Texas
Having gone though these hurdles recently I can provide you everything.
ALLISON TRANSMISSION A59 TCM Control Module, 29551869 is what you need, check ebay for about $600 used. The CIN data is what you need. Simpson posted his and I can get you a pic of mine if needed. Take everything and your transmissions S/N to allison and they will program it.
Truck1951
Alabama
Thank you for you're help
Truck1951
Alabama
Good afternoon I found a tcm and a place in Birmingham to reprogram it I can't read simpson's number can you send me you're con number thank you
fuzzytoaster
3,707
Fort Worth, Texas
Good morning and thank you for you're help I am confused witch cin do I reprogram my tcm with yours or simpsons his is 4C0010M1007C
I can't help you with that one. The only one that can tell you would be Allison by using the transmission S/N to look it up. This CIN was on my 2010 M916. My 2012 M916 is also different. There was likely updated programming as trucks were produced but this is a guestimate.
Truck1951
Alabama
Ok thank you very much
Jeep Nasty
245
NH
Any chance you know the part number for the shift controller? I can pull mine out in check if you don't.
