sl33k3r
- 5
- 3
- Potsdam/NY
I plan a workshop where I have larger 3 phase motors that need high current to start but very little, in comparison, while operating. I do not wish to operate a generator at 1 gph when the generator is at 10% load or less.
Generators can run for hours with less than proper load. The engines do not idle down or even change rpm to meet load. This not only wastes fuel but it causes wear by putting engine components under stress when the energy producing that stress is not needed in the production of enectricity. Has anyone had experience with dropping cylinders. Like hit and miss engines, exhaust valves could be opened to reduce compression and fuel lines to injectors could have electro-mechanical bypass to fuel return line.
I don't believe this type of system should allow the cylinders to be shut off during times that the engine is not at or near operating temperature. The block and head(s) should be warmed as fast as they normally would. Cylinders shut-off should be rotated to attempt even wear of the engine and to keep even heat throughout the block. I am not sure that the coolant will be enough to transfer enough heat.
I believe the fuel pumps are designed to be able to adjust injection timing, but no method for fuel quantity adjustment. Am I correct in my assumption?
I am no diesel genius, so I thought I would ask for clarity on this idea to see where I might be going if I try this type of system on my own equipment.
