Wrenchstench92
- 12
- 8
- Long Island NY
Hello everyone! I haven’t been on here in such a long time hope you all are doing well. I opened my own auto/ truck repair shop I’ve been in business for over a year now.
Anyways, onto my truck.
I have a bunch of things I wanna do to the truck to get it ready for the summer, just renewed registration and insurance
I’m gonna need help/ advice on some of the things I need to do.
1 I need to replace all of the return fuel lines, they all leak, like not dripping but sweating, are there special plastic tubes I need to replace them with or can I use solid steel line and flare them all so it never leaks again?
2 The trans has to come out. I went to check the trans fluid the other day, and when trying to loosen the pipe plug, I lifted the whole gearbox. Opened the inspection plate on the flywheel housing and I see there are a total of 5 bolts holding the gear box to the housing One bolt broke, the bottom most one in the center. The head and like 4 threads came out. The rest must still be in there. 2 on both lower corners I was able to tighten, the last 2 up too I cannot get because they are behind the clutch rod. I see there’s no way to get the rod out in the truck. So I figure I’ll have to pull the trans and I’ll do a clutch, PP, TO bearing and rear main while I’m in there. I’ve seen posts of how others have pulled the trans so no problem there.I have 2 questions on this topic.
-am I going to be able to drill out the broken bolt, meaning how does the bolt stay tight in there? Is there a welded nut inside the trans or something?
-is there supposed to be a rear transmission mount? My truck doesn’t have one. The T case has like 5 points of mounting, seems the transmission has only the flywheel housing/ motor mounts. I am thinking of fabricating a mount because the design seems stupid
3 the right rear leaf pack needs to be replaced. The truck lists hard to the right rear, gotten worse with time and use. It’s not broken just bent. Also would the dog ones need to be changed? I checked them all none are in bad condition and with a pry bar none move.
I’m really sorry about the long post. Just excited to get things fixed on the truck and I promise I will try to get on here a lot more often. TIA
