Unimog Won't Go
pat356jones
Charleston/SC
I have a Unimog FLU-419 and yesterday I moved it a couple hundred yards to do some work and it went forward fine. When I went to back up it would not go backwards. I put it in reverse as I always have but it would not move. I then put it in forward gear and it would not move forward either. I've tried everything - low range, high range, reverse and forward in low and high range, and everything seems to shift fine and the clutch seems OK but it just won't move in either direction. The PTO works OK and I used the backhoe some to do the work I needed to do and I moved it into place using the backhoe but it just won't go forward or backwards on its own. Does anyone have any ideas as to why this Unimog won't move?
Hank Baer
Vermont
pat356jones
Charleston/SC
Was it the air shift solenoid ?
I'm not sure but I think so. It was a part that was difficult to access under the passenger seat area. At first we thought we might need to cut a hand hole under the seat and cover it with a plate but my mechanic friend was able to access it without doing this. All I know is that he fixed it and that it's running great now and moving as it was built to move. Everything is working on it now.
