Crapgame
- 342
- 63
- Navarre, FL
OK, went through the process to replace the portal hub side CV Boot on the right, front Halfshaft of 1994 M1097A1. I quadruple checked the components before stretching the boot over the cup and spindle ends, bearing cage taper side towards the hub. I crimped the CV Boot Bands, went to reinstall it, first by just giving the hub to Halfshaft retainer bolt a few turns to help keep the assembly in place while bolting up to the brake rotor.
When I crawled under to match it up with the brake rotor the shaft is acting like it is too long. I can pull the cup end and the Halfshaft will stretch out but it will not compress enough for the lip on the cup backside to fit against the brake rotor.
When I pulled it, I remember the Halfshaft contracted itself about 5mm or 1/4" or so when the last bolt was removed from the brake rotor.
I tried tapping it in place with a hammer against a piece of wood.
I tried turning the front wheels all the way to the right (which creates the largest distance between hub and the brake rotor). And I tried turning them all the way to the left.
I even attempted to install a NIW 10k Halfshaft Assembly instead, No Joy. Part #12342974-2 from Parts-Liquidator on ebay:
HMMWV/HUMVEE RIGHT, FRONT CV AXLE HALFSHAFT NSN2520-01-382-8728 PN12342974-2 | eBay
What are the odds I reassembled the original Halfshaft incorrectly and the NIW replacement are out of spec?
Anything else I can do without damaging myself or the equipment? I'd rather not be lying under a HMMWV hurting myself while casting 4 plus letter explectives on Easter Sunday as a stupid, inanimate object beats me. Short of ordering another set of CV Boot Bands to start from scratch again, I'm at my wits end.
