- 2,136
- 618
- Davis County, UT
Mr. Peashooter, did you finish installing the larger air compressor? Any information on fitment/alignment or anything else you had to do to get it to work would be appreciated.I haven't given my truck much attention lately but I have been following "LINO" and his well done projects. One of his upcoming projects is to install a higher output air compressor (double the output) and extra air tank. His info on this starts HERE.
So with the idea and info from LINO, I found an air compressor that should fit. Of course our Deuces use a somewhat odd one in that they are considered a "4 hole, base mount" compressor but the kicker is they are also "base oil fed". So their is a hole on the bottom base of the compressor flange where the oil is supplied to from the engine.
I got lucky and found a compressor with this, Lino found a compressor without the base oil hole so he will probably be drilling the hole. I'll post pics of that oil routing in another post incase they help anyone else out.
Below are some pics of the compressor when I got it (all black). Then I bought what I hope to be the best suited manifold kits for the deuce: outlet manifold (Haldex SN3711AH), I chose a filtered intake manifold for now (Haldex KN19040) but those who are doing the fording kits will want something different. I added the manifold kits, and then painted it green. I found the new/rebuilt compressor on ebay for $100 shipped, unfortunately I ended up spending about that for the set of manifold kits since I couldn't find any deals on those.
The compressor I got was a Midland KN13060 but I think Midland sold off this division to Haldex so that's who has them now. Lino and I are hoping these EL1300 series compressors are a good fit. You can find the Haldex compressor catalog HERE
-Stock compressors are about 7.4 cfm
-These EL1300 units are 13cfm.
-There are also EL1600 units that are supposedly high output versions of the EL1300 and they put out 16cfm.
The last picture is the larger air tank that I plan on adding to the truck. ($60 shipped off ebay!, another find by Lino)
