- 1,876
- 1,090
- Paris KY
I am wanting to install the auxiliary fuel tank on the passenger side, and after removing the bed from my M1028, I discovered that the original tank on the drivers side is in pretty bad shape. So I have decided to buy 2 new tanks and replace the original at the same time I install the auxiliary tank.
Question - is there any alternative to buying a replacement steel tank from Summit, JEGS, etc? I believe these steel tanks may be Chinese or other import, which doesn't sit well with me. Is there an American source for a higher quality tank? Has anyone had any experience with the polyethylene tanks from Gas Tank Depot? https://www.gastankdepot.com/2050a-plastic-fuel-gas-tank-chevy-gmc-pickup.html .
I am also going to need the brackets, straps, cushioning, etc. I will appreciate nudging me in the right direction.
Thanks.
Thanks.
