Multifuel fuel filters
Veesandskis
Minnesota
Hey guys, new here so how’s it going!
Anyways, I just picked up a M35A2 last week to go along with my M998. I found fuel filters but finding the correct o-rings has been a struggle. So I can get the wix 15070 which is correct for the secondary filters. (Turns out those gaskets are the oil filter housing gaskets for Farmall M tractors as well so that’s a plus!). The other gasket ive seen is a wix 15131 and no store can get that for me. Well after a bunch of searching on and crossing on wix website, I found a primary fuel filter that’s actually listed for a Hercules, continental, white, etc engine that comes with the correct gasket already. The filter is a wix 33113. Just figured I’d share that for everyone. Thanks and have a great day!
Veesandskis
Minnesota
When I did mine they came with the gaskets in the box with the filter.
Check at the store if you get them in person.
I’ll do that! I just read on here that the gaskets are not quite right that come with the filters so I order the correct o rings and it’ll all be here tomorrow so I’ll post back with what I find
Veesandskis
Minnesota
If possible post back on your findings.
I did not have any issues but I would like to know the outcome you have.
Will do. I’m not completely sure whether mines a Hercules or a white or a continental but I keep hearing the wix/napa filters have the correct filters but they come with gaskets that are too small so I’m not completely sure what to expect. Hopefully all goes well tomorrow. I have all the correct stuff to do the secondary’s but the primary was the one I was having a tough time sourcing the “correct gasket that I keep seeing I need to use. Do you happen to know how to tell which particular manufacturer my engine is?
Veesandskis
Minnesota
I used the Baldwin filters and the o-rings fit perfect. That was on a continental.
Awesome. Not completely sure what brand my motor is if it’s hercules white or continental but I might order those next go around to see. Seems this is kind of a hit and miss situation with these old things 😂
Elk1111
493
Las Cruces NM
I wasn’t real sure. Mine was the old Continental 427. Some of the parts were a bit different especially on the injection pump.
frank8003
4,989
Ft. Lauderdale, Florida
THERE is a guy that has already, within SS, figured this all out and does supply all the filters and all the required proper seals for your filters filters. His filtersz do come with the required seal.
There is no mistake
Veesandskis
Minnesota
So I got my two primary filters I ordered to try on this thing and the 33113 fits perfect and comes with the correct o-ring. Everything went together slick. I’ll have to return the 33511. Still waiting on my secondary’s which will probably be here tomorrow. So if I were you guys I would try out the wix 33113! Same micron as the 33511 and same size filter plus it comes with the correct o-ring.
Gunner0311
Millington, Michigan
I am having similar problems today, as I found my M52A2 will not start up! Appears to not be getting fuel? I am hopeful the problem is the fuel filters, which I have not change since the truck was rebuilt by the USA several thousand miles ago. I am trying to find filters locally so I get get the old girl running today, but cannot cross reference military t commercial fuel filters! Searching for a cross reference chart has found nothing?? Does anyone know of a commercial fuel filter part number for the M52A2 LDS-465 turbo diesel motor??
davidb56
1,238
Bonners Ferry Idaho
If you want to save time playing internet tag and researching, pull the fuel line off the tank and turn on the ignition (don't crank) to make sure the internal tank is pumping. If yes, reconnect it and go to the frame mounted primary fuel filter. loosen the discharge line and turn on the ignition again, fuel should squirt out under low pressure (maybe 5-10 psi. Just work your way up. Starting on a fuel problem in the middle is confusing sometimes.
frank8003
4,989
Assure in tank fuel pump functioning. Put a gauge on it
