Run flat Removal
charlesmann
713
Temple, Tx
395/80 R20 Goodyear MT/V tire with a run flat. How have some of y'all gotten them out? iv seen youtube vids of strapping the tire to a tree, or some other solid object and yanking them out. I dont have anything that is immovable or anything that has the grunt to yank them out, except maybe a 12k winch, snatching it for 24k, and maybe strapping the tire to my tractor loader forks, butting the tractor to the rear of my gooseneck loading ramps, in the stowed position.
Thoughts/advise? i had thought about, if other tires had it in them, outfitting all 7, but 1 out of 7 isn't enough for my to mess with sourcing 6 more.
I do though need 1 beadlock ring, which looks like it bolts together, to make instal into the tire/wheel easier. Any ideas on whom might offer them?
simp5782
Feo, Fuerte y Formal
9,496
Mason, TN
No tree with a fork? Or 2 trees? You have the tractor with forks.
Or leave the one with the runflat as your spare so you have something that can really get you home if needed.
simp5782
9,496
Mason, TN
And you also have a wrecker don't you? Strap tire to the pintle hitch or both shackles. Hook run flat and use the crowd on the boom to pull it out if you need more umph use the boom winch. The winch is stronger than the crowd, lift cylinders and turn table hydraulic pressure
charlesmann
713
Temple, Tx
well, the wrecker is on jacks with both left rear tires off, and the tires that were on it, broken down. I still have my hubs off waiting on the machine shop to finish some work on them.
simp5782
9,496
Mason, TN
Wrecker isn't going to move doing that work it would be fine to use
