shotty
- 56
- 28
- Northern VA :(
Installing a 4k RPM C60 tach, and according to https://www.steelsoldiers.com/threads/factory-tach-install-will-it-work.100057/post-2179753 " When you wire in the tach, do not tap into the ignition 12+ wire in dash wiring harness, when the glow plugs cycle, it kills power to the dash, so the tach will read zero when the glow plugs are lit or cycling. "
That... doesn't sound right me. Of course my truck is in pieces right now so I cant verify. I would love to use the ignition power going to the dash already as that makes sense. Any ideas?
