m929 electrical diagram
mike1976
marshall mo
looking for the location in the TM for the electrical diagram I am having troubles downloading and reading pdf files with my slow internet
20,653
Hi Mike.
Something worth considering is a thing called the "M939 Series Interactive Systems Guide". It has electrical diagrams in it for sure. http://www.steelsoldiers.com/upload/939/M939_P2P.zip
The TM with electrical diagrams... Not as easy, but I was able to pull out just the electrical for you from TM9-2320-272-24P-1. It is a meg and a half, so hopefully your internet connection will haul that down easily.
simp5782
Feo, Fuerte y Formal
9,497
Mason, TN
What are you trying to do or what is your truck doing I can give you pin and wire numbers
mike1976
marshall mo
lost power to the light switch found the test procedure and tested wire 15 found no power there was trying to find where it gets it's power ended up running new power wire so the truck could be used
simp5782
9,497
Mason, TN
15 is spliced in with wire 81 that receives its power from the positive post at the starter solenoid. So just run you a new wire from there so it has full time 24v
Dougs1
11
Nevada
hi guys
new here so i hope im not beating a dead horse.
Im having trouble loading the p2p. could someone guide me through the process?
thanks
20,653
hi guys
thanks
P2P isn't all that fancy,
Do you have the file ZIP?
Short version of the install is to put it into a "root" folder. C:\P2P or something like that. You want to run "nav.a6r" in a DOS box in Windows.
Does that help at all?
Do you need more info?
