Cab lift hisssss when activated
Ronmar
8,174
Port angeles wa
Where exactly is the air coming from? Could simply be a leak and the air piston cannot build enough pressure to cycle against the hydraulic resistance. It could be the mechanism is stuck mid cycle or has a bad air piston seal… someone did a video showing an overhaul, think it is on youtube…
Floridianson
2,525
Interlachen Fl.
Control knobs not in correct position? I put all of them on where they are supposed to be not half way in between even if the function is not the one I need.
Suprman
706
Stratford/Connecticut
There are 2 types of control pushers. Unscrew it see if there is a small cartridge behind it. The cartridges go bad and when you press the button air will just come out a vent on the back of the hyd box.
Awesomeness
1,521
Orlando, FL
Hard to tell from the video, because we can't hear where it comes from.
Pushing that button sends air to the pump up behind the cab/spare. Could the be the air line, the pump, or the button (probably in that order).
BERZERKER888
894
Daytona, FL
I am completely giving up on this 1081 because of the owner appears to have veracity issues.... on to the next !
