MEP-803A Injector Pipe Nut Torque Value Wrong in Manual
kloppk
4,205
Massachusetts
Earlier in the manual in 3-12 it does call out "Tighten injector pipe nut (2) to 21 ft-lbs (28.5 Nm)."
It would look like 21 ft-lbs is the correct value.
Chainbreaker
2,112
Oregon
Also, using a Nm to ft-lbs converter 28.5 Nm = 21.02 ft-lbs. If you take the "printed" value of that TM "21.0 in-lbs" and convert to Nm it comes out as 2.37 Nm.
Thus, I would say "Confirmed" 21 ft-lbs is the correct value to use.
