- 2,490
- 1,905
- Efland, NC
First post here in this section. I searched around a bit to find the info on the engine speed sensor since the M1081 I recently purchased had a tach that didn't work. I didn't find a post with a concise breakdown of the problem so I decided to make one. I was thinking that the sensor was the likely culprit since the transmission shifted really hard.
First thing was to test continuity on the sensor and it was OPEN CIRCUIT where in the TM it indicates that the resistance should be less than 1440 ohms.
The sensor is on the bell housing at about the 10-11pm position if looking from the rear. You can see the bung it threads into here:
Upon removal it was obvious someone had NOT read the installation instructions.
Per another thread here on SS I read where there was a potential replacement. I ordered it from NAPA and it looked to be OK. The connectors were different but that is easy enough to take care of. I'm not worried about it being plastic since its not in an area where there are super hot things like exhaust. Its on the other side of the engine from that stuff.
I cut off the connector from the old sensor and soldered/heatshrinked it to the new sensor. Reinstalled per directions - thread in until it bottoms out then back off 2 turns and lock it down with the jamb nut.
To my delight the tach now works and after a 10 mile test drive the transmission is shifting a LOT better! I hope this helps if anyone else is in the same boat.
