Glider
- 227
- 43
- South Pittsburg, TN
My M998 shifts the same regardless of throttle position. It barely gets moving before it shifts into 2nd and then shifts into 3rd fairly quick. It will not downshift from pedal input. It will downshift when slowing to a stop as one would assume a properly operating trans should. When accelerating from a stop with average throttle and manually shifting starting from 1 position it accelerates much better without taxing the engine. I have read about the downshift switch on engine. I don't think it is working or is improperly adjusted. I'm asking questions now so when I get started hopefully I can find a bad part or properly adjust everything in one session. My question: What is the best order of adjusting and checking components? Is there an adjustment on the transmission? If this has been covered already I didn't find in my searches. I've seen threads about the downshift switch that I am assuming pertains to full throttle shifts. I want to fix that but would like the trans to hold gears longer at part throttle also.
Any input appreciated
