How well does AC in the MTVR work?
Russ Knight
1,054
Perry, FL
Thinking of installing AC in my MTVR at some point after it's arrival. I have the Red Dot AC in my M925A2 and on those really hot summer days, it just doesn't do a lot to cool the cab down. It helps, but you'll never reach over to turn it down because it's getting too cool. So, question for those who have AC in their MTVR is, does it work well enough to justify the expense of installing it?
BKubu
1,164
Gaithersburg, MD
I had a RED DOT kit in my now-gone M925A2 (with a soft top no less) and I found it to be plenty cool. I never measured the temperature, but I never had a complaint with its performance. I recall once having it out a 90+ degree day and I eventually turned it down. I did eventually switch to a hard top because they provide more insulation. I have no experience with the MTVR A/C kits, other than I own one for my eventual acquisition.
Camoguy
Oxford nc
I just installed mine about a month ago. It actually blows pretty cold. Only complaint would be that the vents are not in the best place to point them at the driver. Overall I like it.
Camoguy
Oxford nc
Does it cool the cabin down?
Not like my other truck. But it’s an Improvement for sure. If you sit in the middle in-front of the vents you will want to turn it down. Be ready to fight the driver😂.
I bet sound proofing/insulation would help. Keep in mind its mostly a aluminum shell. I haven’t plugged all of my armor bolt holes either.
JW7tonWY
144
Central Wyoming
One summer under the belt on my kit installed on MK23. It is better then not having it, keep the cooler in the middle and the ice won't melt, but get fans for the driver and passenger to help move the air over from center. 100 degree day reasonably comfortable for driver and right side passenger. About the same result as the heater at 0-10 below, comfortable but only just.
JW7tonWY
144
Central Wyoming
I added my Oshkosh AC kit last summer, 90+ full sun on cab it is nice in the cab with A/c full blast. Last week I added a vent, and what a difference, lost a lot of back pressure in the manifold and the cab is a lot cooler. blows on the passenger direct, still get the same air flow from dash and drivers vent. If you live someplace warm get the AC. I have a y pipe with valves and will be doublingIMG_1476.jpeg up the drivers vent outlet next, one on each side of the steering wheel.
