M1030M1 cable needed
Lionel
24
Baltimore/ MD
Before I go the route of getting Motion Pro to make one up, does anyone have a compression release cable? It goes from the CR to the KLR choke lever. And…. if I have some made, does anyone need one?
glcaines
2,806
Hiawassee, Georgia
Have you confirmed that a choke cable for a KLR650 won't work? I have no idea, but you might want to check. HDT tried to use as many standard KLR650 components as they could.
Lionel
24
Baltimore/ MD
Thank you. I have one original that came on a second bike with a straight in threaded ferrule at the thumb lever. But, the compression release end does not have a large enough barrel fitting for the lever. All the KLR cables I’ve found have a 90 degree fitting up top and again are too small at the CR. Thanks again for replying. The guys at the Kawasaki dealership were no help whatsoever.
