If you can please look up (SPEEDWOBLE) the FLU-419 M35C Whole Cylinder part # is G109186 I need to know the dipper GLAND LENGTH
The Dipper has a different gland than the 580. The 580 uses the same gland for the SWING / Stabilizer / Dipper Cylinder. In the flu-419 M35C because of the folding aspect the gland needs to be shorter in the dipper and the swing(I believe) In the ARMY manual Dipper is given # NPN-242 (page 461 ARMY TM 9-2420-224-24P no NSN) swing is given NPN-240(page 457 no NSN) Bucket is 1543118C1(page 449 NSN 3040-01-241-4900)
I installed the Case 580 gland 1543019C1BA also known as (1543003C1 or 1543019C1) now the unit will not latch because I believe the gland is too long, I need the length to tell the machine shop what length to band saw it down to. Thank you!
Here is where the 35C is in the catalog:
![backhoe.PNG backhoe.PNG](https://www.steelsoldiers.com/data/attachments/598/598959-0dcafa7f29e6bb5a8fd2ce1defd5d647.jpg)
![35C.PNG 35C.PNG](https://www.steelsoldiers.com/data/attachments/598/598960-af6722d49cb5b03834391da2b5ee49c3.jpg)
I have photos of the prototypes from the 1980's and can confirm that they modified the dipper arm itself to swing tighter(It has paint burnt off so we know it was cut and welded on.) I don't know if they changed anything on the hydraulic cylinder, but it is obviously a different color, so maybe.
![1984_B.PNG 1984_B.PNG](https://www.steelsoldiers.com/data/attachments/598/598969-f3ff63dfda61d09d8ead31b49a848022.jpg)
Cylinder G109186 uses Gland assembly 1543018C1, which consists of 1543019C1 plus seals. Sorry I cannot post images. 1543019C1 fits many CASE models from 1966 to 1993 and has a length of 3.38" (1.4" from the end of the threads to the end of the gland).
I backtracked and the Gland for both the stabilizer G109140 and the Dipper G109186 is 1543019C1 in CASE's catalog, but NPN-242 and NPN-241 in the military catalogs. The NPN are not CASE numbers. That made me wonder... Is the
M35C backhoe on the SEE a
Military version of the 35C and thus distinct?
Then my friend told me to look closer at the parts drawing for G109186 and I saw "M35C-Bhoe UNIMOG":
I looked back in the parts catalog for the 35C and it's cylinder is G106682, not G109186 as for the FLU. They are different!
G106682: 33.87" stroke, 47.5" closed
G109186: 35.12" stroke, 48.83" closed
Both use the 1543018C1 Gland assembly with 1543019C1 Gland!
