wetandmuddy
- 11
- 3
- North of England
Hello everyone and greetings from the UK
I really hope that you can point me in the right direction to troubleshoot an awkward electrical problem with a 1989 FLU SEE that has been standing for 10+ years. It's got 150 hours on it and 2,200 miles.
After a bit of fresh fuel, some new lube and a handful of filters the machine runs and drives fine, but I am struggling to get all of the dashboard functions working again.
I've repaired all of the visible issues (there was a bit of rodent damage behind the dash, etc), I've cleaned all junction blocks, replaced all fuses with new ones and tested and replaced as necessary all of the relays. All of the earth connections are good and everything now looks just right.
The issue is as follows: some of the dashboard warning lights / functions work and some don't... for example the charge warning light works but the main beam warning light does not (both bulbs are good - I've swapped them round). The turn signal warning light works but none of the 5 warning lights beneath the inclinometer work, nor does the fuel gauge. In contrast, all of the exterior lights work, as do the horn, the wipers, the temp gauge, the voltmeter, the interior light, the hazards, the turn signals, the BO lights, etc, etc. So it's clearly a bit of a mixed bag...
I've got the simplified version of the wiring diagram but this is not detailed enough for me to do a proper troubleshoot.
On the other hand, the troubleshooting sections of the maintenance and technical manuals deal with very specific individual faults (eg a single warning light does not work) whereas my issue is something more simple and more general than that (eg none of the 5 warning lights below the inclinometer work, although all of the bulbs are good and the shared earth is intact).
So, does anyone happen to know where I can get a full wiring diagram? Does anyone know precisely which relay corresponds to which one on the simplified wiring diagram? Does anyone know precisely which wire in each D-connector on the fuse board corresponds to which wire on the simplified diagram? (Why doesn't the simplified wiring diagram show the relays and D-connectors in schematic form so that the reader can identify which wire is which??!!)
Very few of my wires are labelled with numbers, and of course they are all black!
Please, can anyone tell me where I should start with this problem?
Your help is very much appreciated!
Andrew.
Andrew.
