I working on a MEP 804A having problems with the high water temperature switch I have checked it with my ohmmeter and checks out ok I hook it back up and it goes down on high temperature and that is with the engine cold I have24 volts to the switch and I’ve ohm the other wire out and it has no Resistant can any one help me out Thanks
Hi Larry,
Welcome to Steel Soldiers!
Guessing you just joined up to get some help with your MEP - as well as being introduced to this bunch of fine folks here.
You might get more attention to your post if you put one in the Generator Section.
Gensets
www.steelsoldiers.com
Several of the guys here have forgotten more than I will ever know about the MEP, but having a new thread in the right forum will get attention for sure.
I have to admit that I don't know anything about making power. Just so you know, the TM's (Technical Manuals) are downloadable on this site. Free, so be sure to download whatever you need. There are
troubleshooting steps in those books.
Find TM's for MEP and other generators in this forum. MEP-002A, MEP-003A, exc. - No posting of threads
