BERZERKER888
- 896
- 93
- Daytona, FL
Figured it would be a common item….nope… any sources or equivalents out there ?
Locking fuel cap | Amazon | sloan 431091 | FindItParts | B002ACJ2HI or 431091 | Amazon/less costly vendor? | Sloan 43191 |
.I saw that and a much cheaper one that Sean Filner installed...cap is fine , gasket needs attention...
that's probably the route I'll take.. but for God's sake a standard 4" gas cap gasket is nowhere to be found....geeeeze.
What about a roll of thick fiber-type gasket material and a pair of scissors?
.that's probably the route I'll take.. but for God's sake a standard 4" gas cap gasket is nowhere to be found....geeeeze
I had to make one out of rubber sheet gasket material.Figured it would be a common item….nope… any sources or equivalents out there ?
well Awesomeness.. there's your next item on your to so fab list..... along with cab bushings !I had to make one out of rubber sheet gasket material.
... or use this tool. (don't forget to add a little bit of wodda' , for lubricant....So if you can trace a circle and use scissors....
And of course there are the "non-surplus" variants for 1/100th the price... or use this tool. (don't forget to add a little bit of wodda' , for lubricant....)
