- 7,408
- 2,501
- Interlachen Fl.
OK do not know a thing about any of them. I bought this old diesel light tower that has been converted to just power. Kohler and she runs at 1800rpm. The guy I got it from wired up a 240 volt plug and two 120 plugs . My data tag says 67 amps 120 and 33 amps 240. Now the light tower has the main breaker at 25 amp. As it is I now can run my 240 well then unhook then hook to the 373 trailer for 120 volts 30 amps for AC, TV - play station and lights. Now the wire coming out of the head is only a # 10 stranded and per specs it only goes to 30 amps. So my question am I correct or can you pull out more amps with that 10 wire.
