1997 FMTV CAT 3116 Crankcase Vent slobber tube excessive oil
chucky
18,844
TN .
So overfill with diluted oil? What do I dilute the oil with?
no hes saying to check to make sure its not overfull or if it looks diluted with something else like diesel or water/antifreeze mixed in the oil
chucky
18,844
TN .
Oil looks fine and dipstick shows it is low.
I would just run it and keep an eye on it and keep the oil at the full range . Have you ever changed the oil since you got your truck ? I use shell Rotella 15/ 40 in mine and ONLY USE CAT FILTERS except for the small fuel filter with the plastic bottom on it !
Ironcladz
seattle
I have not changed oil yet. I'll give it a go.
