MEP-803A Need p/n for coolant high temperature switch
tom250e
Northwest Louisiana
Hi folks!
I'm new to the forums and have found some great information here. I have also downloaded the TMs for the 803 and after searching through them am still unable to find a part number for this switch. I have read some posts that refer to an NSN cross reference list but am unable to locate it in the TMs I have (TM9-6115-641-24, TM 9-6115-642-10).
Being a noobie and all I have probably overlooked the info I need; so if one of you gents would kindly point me in the right direction I would very much appreciate it.
Thanks!
20,778
Hi folks!
Thanks!
Welcome to the outfit Tom!
There are several guys on here that are really sharp on "making power".
Chances are the "military name" for it is different than how you are searching in the TM's
I did a quick search myself and came up empty...
I imagine the guys will come along after dinner and get you started down the right path.
kloppk
4,205
Massachusetts
It's in the -24P TM. The engine sensors are later in the manual than the up front electrical stuff.
You can search the 88-22203 in the TM. It'll show you where in the TM its shown.
20,778
Thank you "Light In The Dark" and "kloppk"!!!
Really, really good to know stuff!
For sure - and the right name to search with is the real magic.
Trucks are more my thing.
I kept searching for a rubber "bushing" and I never could find it. Going through the TM page by page, I finally found "cab support" to be the proper term for the part I was hunting for... It gets better the more you talk to others and the more you rummage those BORING books. They darn sure aren't very entertaining!
Guyfang
27,263
Burgkunstadt, Germany
Take a look at TM9-6115-642-24P. As you page through it, you should notice, it deals with the Generator set. By and large not the engine. There is a separate TM for the engine, If you look in TM9-2815-253-24P, thats the engine book. You will look to no avail in the 253-24P for the Temp Switch. So that tells you this engine can be used in other applications. And that means you always look to the back part of the Gen Set book, 642-24P. In the table of contents, you will find a heading listed:
Group 09 Engine Accessories ......................................................................................................
Frequency Adjust Cable ......................................................................................... 19-1 19
Engine Accessories ............................................................................................... 20-1 20
In the ENGINE ACCESSORIES, is listed all the special gizmo's that are specific to this generator application.
tom250e
Northwest Louisiana
That REALLY helped clarify things for me! Thank you for sharing your knowedge and experience!!!
