Muff too tuff
Maxjeep1
1,930
Las Vegas Nevada
I’m trying to remove my muffler and the converter pipe. Basically everything from the Y-pipe to tip. I have been underneath it and I don’t see how it comes out with the body on. I looked at diagram in the TM and mine looks different. M1123 I believe it to be an A2 but it looks like I have the bracket with bolts that hold the body mount on. How do I get it off? Can I get the cat part out and leave the muff in place? Anyone take a muffler off that intended to re install it?
Maxjeep1
1,930
Las Vegas Nevada
Really? Nobody has taken the cat section out of their exhaust? Ok I will figure it out and I will tell you what to do and what not to do. Might even put a Magnaflow on it. I see the cat is a different color and I know it’s a heat source that needs to be replaced.
jkcondrey
141
Rutherfordton, NC
I have pulled the entire exhaust out and did not have the issue you noted. I would think maybe it had been tinkered with by someone else. The ypipe disconnects and drops out, then the middle section and then the exhaust tip or fording pipe. Drop a few pics of the connections your seeing as trouble.
Maxjeep1
1,930
Las Vegas Nevada
Thanks. I’m getting ready to get underneath. The bracket on top of the muffler is the one that looks impossible to get at.
jkcondrey
141
Rutherfordton, NC
That part really only has like one bolt attached to the shield on top and then on the sides. You can remove the rear elbow/tail pipe first, then unbolt the middle from the y pipe and the transfer case bracket if its still there. Then you should just wrestle it out.
Maxjeep1
1,930
Las Vegas Nevada
I don’t know how I would ever get this back on even if I could get it off. This is the top of muff taken from the rear of it. After further review I think you have to drop the tank and get it between the drive shaft and body. I need to change the gasket on top of the tank and I was waiting for it to get down to 1/4 tank before I drop it. I will do exhaust while I have it out. 5EED5699-F8E8-460A-A5B3-BF1B5F0A26E4.jpeg
jkcondrey
141
Rutherfordton, NC
TM 9-2320-387-24-1 Go to page 3-49. It walks you through it. I did not have driveshaft out when I removed it. But, if it gives you more room it will help. You have to reach up and over for those bolts. I do remember using a jack to raise it up when i reinstalled, just to help hold it. But the instructions do mention you may need to lower the driveshaft for access. But I am 6-6 with long monkey arms so I did not do so.
Maxjeep1
1,930
Las Vegas Nevada
Awesome! I’m headed there now
Maxjeep1
1,930
Las Vegas Nevada
I can’t find that TM. I searched the number in the TM section and I looked under the M998 TM’s also.
I think I found it!!!
AAVP7
263
Dortmund, Germany
Those four screws are set into two metal strips inside that rubber loop. Since disassembly was truly a fight, for easier reassembly I welded the screws to those metal strips, using the bracket as a template.
That way, I didn´t need to hold the screws with one hand while tightening the nuts with the other. Instead I could just put on the nuts, and then tighten them with one hand. I also used a ratcheting wrench. Makes work in that tight spot much easier.
Maxjeep1
1,930
Las Vegas Nevada
Did you try to unbolt the bracket from the frame rail? And leave it attached to exhaust?
That was my first thought but the bolts go thru the frame and hold the body mount on. I don’t see how I can get them out because they are really close to the muffler
Action
1,564
East Tennessee
You can remove the rear propshaft to get more room to get to those bolts. I recall using ratcheting wrenches the last time I had to do those bolts at the top of muffler. I think I reached them from the wheelwell area but not sure.
Maxjeep1
1,930
Las Vegas Nevada
I think that’s the only way I can get to it. I just can’t get around as good anymore. I have to take the shaft out to get the tank out to replace the gasket. I’m thinking I do the gasket and exhaust at the same time and I know I can get up in there. They really got lots of stuff in a small space.
20,711
Typical HumV for stiff body hobbyist. Pull the wheel, hop on the rollie chair, get up in there and work it.
One beer per nut, including wheels, CAMO
Gotta have fun if we are going to work on these green toys!
That sounds like fun to me. As long as you can walk back in the house when the job is done :cool:
