Warhammer1
- 93
- 18
- Plano, TX
Hi everyone, well my turn signal and hazard functionality on my '94 M998A1 went south:
Left turn signal, green light on the unit blinked but faded until it didn't light up at all. The left front bulb blinked dimly but then faded out until it no longer lit up. Left rear never lit.
Right turn signal, only the right front bulb flashed and the rear never lit.
Hazard setting, none of the lights flashed.
I unscrewed the 4 housing screws and cleaned/lightly sanded the contacts inside the unit and cleaned my grounds in all the light buckets, plus verified good bulbs. I then used my multimeter to test open/short conditions on the pinouts using the guide below - of course all the tests failed. When I re-assembled the unit, the green light indicator on the turn signal assembly never lit up and now none of my flashers lit up - I have a feeling I screwed up the tension on the copper contacts when broke the factory seal.
https://www.youtube.com/redirect?ev...tmilitaryequipment.com/content/amgtm998a1.pdf
This is a pic of my current turn signal switch and a new replacement is just over $300:
My question is can I use a unit like this one below? It's around $100 which makes this a more appealing replacement:
I scoured our Steel Soldiers resource for a similar discussion and nothing showed up on the interwebs either, so I'm confident I didn't post a dupe (at least i hope not). Thanks in advance for whatever good advice you can spare...
