Russ Knight
- 1,060
- Perry, FL
The air lockers on my truck aren't working. You can here them clicking but they won't engage. Where should I start?
They are lighting up but they aren't locking in the diffs for sureApparently, I have discovered, there is an interlock that will not allow the axles to all lock if the CTIS is in highway mode. In any other mode, all three of the axles lock, or at least the indicators on the dash say they are locking. So, if your CTIS is functional, set it to any setting other than highway and see if they lock.
Only one axle indicator would light up before I learned to change the CTIS setting. I'll get my son to help me tomorrow and get under the truck and listen to see if I can hear them engage (or not) while he changes the setting.They are lighting up but they aren't locking in the diffs for sure
I put it in a position where it would need lockers to go forward. I could never get it to go with em only the rear would pull. Even climbing the trailer.Only one axle indicator would light up before I learned to change the CTIS setting. I'll get my son to help me tomorrow and get under the truck and listen to see if I can hear them engage (or not) while he changes the setting.
.I'll monkey with them. Hopefully I can get them working.
Easiest way to test is with the little flathead screw driver I mentioned and twist the little red knob. If you hear air move through there’s about a 90% chance that one locked under the truck as the engagement system under the truck is very robust but the electronic solenoids that you bypass using this test is the weak point in them.I didn't have time to mess with them this weekend. I think the first order of business will be to determine if the solenoids are operating and sending air to the locker mechanisms. Once I determine that, I'll go from there. If they are getting air, the old MM oil trick will be applied.
Thanks Eli!Easiest way to test is with the little flathead screw driver I mentioned and twist the little red knob. If you hear air move through there’s about a 90% chance that one locked under the truck as the engagement system under the truck is very robust but the electronic solenoids that you bypass using this test is the weak point in them.
So go through all 4 of them engaging and disengaging. Also don’t drive on the road with any of them locked.
Fourth one is transfer case lockupIs there a device that controls (latches / unlatches) the solenoids when sequentially locking or unlocking of the axles each time the switch is pressed? Also, there are four solenoids. I know three of them control the individual lockers on each axle, but what does the fourth one do?
Easiest way is find a ditch, these trucks do not articulate well at all, and quite frequently if I hit my driveway idling in off the road (slow speed) and my truck flexes the rears will simply quit pulling and I have to gently mash the brakes to stop the free rolling wheels and engage my rear lockers then continue idling in. Be careful engaging the lockers with a tire spinning as there is NO safety and you can actually damage them if engaging while one is actively spinning. The operation TM covers this and I’ve actually found some teeth tips in my rear differential from it’s time in the serviceDiscovered the hose going to the center locker has a big hole in it. Will replace it and see if the axle will lock. having said that, what is the best way to determine if the axle is locking without chaining the truck to a giant tree or something?
