cookeemann
- 22
- 8
- Woodbury, GA
I read the TM, but couldn't find pics for this procedure on 'net. Maybe this will help someone with their IP issue.
Truck wouldn't start/ no fuel to injectors. Drained tank, clean fuel in, pressure fuel into and out of filter housing, had fuel at rubber return hose on IP, both solenoids click, throttle was stuck and was hard to press accel pedal when picked up at auction. Bad IP.
Removed intake. Removed oil filler tube to access IP mount bolts inside vs removing timing cover. Removed glow plugs.
Marked/bagged everything to keep it simple.
With intake removed you can access the pump. I covered intake ports, numbered fuel lines. Disco lines at all injectors.
Scribed a line on engine to match the timing mark on the pump. This is critical for pump timing.
