- 715
- 992
- 93
- Southern Minnesota
I finally got around to diagnosing my wiper motor not working. After removing the soft top and side rails, I was able to tilt the windshield forward and found two "contact assembly" ( 5999011839530 ). I cleaned them, added some dielectric grease and got it working.
However, when I re-attached the side rails and soft top, it all stopped working. I suspect it's pushing just slightly forward causing the connection to be lost.
I found that Hummer Parts Guy selling these contact assembly's for around $48 each, I'd need two if I ended up going with this.
However, looking at the TM-9-2320-280-20-3 Maintenance Manual (part 3), Section 10-23. The picture there seems to show a wiring harness and grommet instead. This certain would prevent future failures in the contact assembly.
Is there some sort of wiring harness adapter that I could use to replace the contact assembly? I know I can make my own small harness, but I don't know where I would find a grommet for it though.
Any suggestions on what I should do? Fix it, buy a harness, make a harness, etc?
