Tensioning the power steering belt
18E40
13
Huntsville, Alabama
What a PITA it is to tension the power steering belt. I did this job previously over a year ago when I first bought the M1009 and I replaced the ratty belts. Today I installed a Fluidampr and when I went to tighten up the power steering belt I couldn’t remember how I did it so I decided to use a ratchet strap to hold the tension while I tightened up the nuts/bolts. Hope this helps someone.
jcollings
421
Jupiter/FL
I use one of these bars off the frame with some spacers I'm spacers to gently move the bracket.
but have this 2nd picture device coming , which will make it a breeze, But they are a real POS of an adjustment.
Sent from my SM-G975U using Tapatalk
jcollings
421
Jupiter/FL
I wish it had a serpentine belt wow that would be better
deank
586
Inverness, Florida
On my M1031 the power steering pump has four bolts. One at top left is the pivot point. The one at lower left and the one behind the alternator are for adjustment. But there is one more below the one on the alternator bracket. Just below the temperature sending unit. Engine side is 15 mm for adjusting tension, on the other side use a 7/8 socket to pull the pump to tighten the belt.
