Adding TPS to a 6.2L
Mogman
10,246
Papalote, TX
I am sure some have done 4l80 conversions to 6.2L HMMWVs I am in need to add a TPS (throttle position sensor) to my 6.2L and know there are many ways to do this, they make "universal" cable operated TPS units as well as ones designed to attach to the gas pedal/linkage under the dash.
So I was wondering if anyone has found a reasonable way to add a TPS to the 6.2L
simp5782
Feo, Fuerte y Formal
9,493
Mason, TN
This is what is used on the 6.2 6.5 with 4l80e
Mogman
10,246
Papalote, TX
So the TH160 just bolted up to the pump and indexed on the pin that is driven through the throttle shaft, that would be too easy!
simp5782
9,493
Mason, TN
I did it back in 2009 with a 6.9 IDI when I went from a 4spd to an E4OD. I had a thread on oilburners. I'll see if I can find it.
Mogman
10,246
Papalote, TX
The TH160 looks like the way to go, read the instructions you provided and it looks just that easy, well nothing is really easy when working on the IP......
Mogman
10,246
Papalote, TX
The TH160 came in today and as advertised it bolted right up to my mock up 6.2L IP, that is one of the tasks fixed easy!!
As long as I can get my fat hands in there to install it!!!
THANKS!!
